I am considering installing a 2-Watt 18 Ohm resistor in series with the new rectifier diode to prevent current surge and to drop the B+ down to within specifications. Would this be a good value to use? Or should it be more like 100-150 Ohms at 5 Watts? Thank you in advance for your help.
Poston
:I am currently working on a Philco AM portable Model #53-642, I have replace the selenium rectifier (and the filter capacitors) and I've notice the plate voltage on the tubes is anywhere from 2.5 to 10 Volts higher than the schematic. Although the radio works, I am concerned about inadvertently shortening the life of the tubes.
:I am considering installing a 2-Watt 18 Ohm resistor in series with the new rectifier diode to prevent current surge and to drop the B+ down to within specifications. Would this be a good value to use? Or should it be more like 100-150 Ohms at 5 Watts? Thank you in advance for your help.
