Magnavox Astro-Sonic
12/26/2002 3:17:02 AMMai
i got a hold of a magnavox astro-sonic model 1P3733 with a phonograph for a year now its been working great, now i am having problems with the phonograph, sometimes it shakes while it is spinning, sometimes it doesn't spin, and other times the arm wont move, then sometimes i have no problems. i don't know much about electronics , not alone old ones. Looking for information about my astro-sonic, any kind of information because i don;t know anything about them! help. thanks
12/27/2002 2:23:42 PMPoston Drake
Hi Mai,
It is very likely the only problem with your record changer is dirt and/or lack of lubrication. Carefully remove it and support it upside down on your workbench. Use a dry brush and/or vacuum cleaner to remove as much dust, dirt, etc. as possible. Wipe off any dried grease with a solvent such as mineral spirits or lacquer thinner. Relubricate all gears, sliding pawls, etc. with a very small quantity of light grease, such as Lubriplate. Apply small quantities of light machine oil to other mechanisms, including the motor bearings. Then invert the changer, right side up, and try to figure out how to remove the turntable. Usually there is a split-ring fastener at the base of the spindle which when removed will allow you to lift the turntable up and off. Apply a few drops of very light machine oil to the bearings at the base of the turntable. Clean any rubber drivewheels with rubbing alcohol or a commercial rubber platen cleaner, and be sure to keep all oil and grease from rubber surfaces. Hopefully this will cure your problem.
Poston
:i got a hold of a magnavox astro-sonic model 1P3733 with a phonograph for a year now its been working great, now i am having problems with the phonograph, sometimes it shakes while it is spinning, sometimes it doesn't spin, and other times the arm wont move, then sometimes i have no problems. i don't know much about electronics , not alone old ones. Looking for information about my astro-sonic, any kind of information because i don;t know anything about them! help. thanks
