Any chance that you have any color coded info on the unit.....or have you viewed the bottom side of the
unit, in case it is mounted against the chassis.?
Edd
::the cap is removed since I suspected it was bad...nothing anywhere on it
:::Hello, I have an aero vox cap that has no value on it except the patent number on it. The number on it is 1650395. It is long rectangular flat brown and what seems to be bakelite with two round ring terminals coming out of the end of it. The cap also has holes in it at the ends.....for mounting?
::Any chance that you have any color coded info on the unit.....or have you viewed the bottom side of the
::unit, in case it is mounted against the chassis.?
::Edd
