crosley model 56tv(0) radio schematic
12/9/2002 3:20:10 PMmanuel j pereira
i just bought what it seems to going to be a project radio crosley 56tv (o) radio the tubes light up but radio is dead (tubes tested good) there seems to be a resistor at tube 35z5 that has been cut in half, and some one wired electrolitic caps. what i need is a wiring diagram for this radio riders on line does not list this radio and i have been looking for a schematic that is equivalent and cant find it any help is appreciated. when i conn the resistor to the other side whre it seems that it was inst the radio works very low with volume turned all the way up
12/9/2002 3:40:21 PMNorm Leal
Hi Manuel
Try 56TW or others. These schematics should be close to your radio. Even if your radio has different tubes functions will be the same. 35Z5 is the same as 35Y4, just different base.
http://www.nostalgiaair.org/Riders/CRO.htm
Replace the electrolytic filter cap. It's most likely 30/50 @ 150 volts. You could use individual units. 33 @ 160 volts and 47 @ 160 volts are available.
Use a 1500 ohm 2 watt resistor between filter cap sections.
:i just bought what it seems to going to be a project radio crosley 56tv (o) radio the tubes light up but radio is dead (tubes tested good) there seems to be a resistor at tube 35z5 that has been cut in half, and some one wired electrolitic caps. what i need is a wiring diagram for this radio riders on line does not list this radio and i have been looking for a schematic that is equivalent and cant find it any help is appreciated. when i conn the resistor to the other side whre it seems that it was inst the radio works very low with volume turned all the way up
