Here is a 25. See if this matches?
http://ww3.nostalgiaair.org/schematics/CRO/_CRO_12-17.gif
:I have a Crosley F-25 that blew a cap but I don't know what the value of that cap is. I am looking for a set of schematics for this if anyone has a set. Can anyone help?
:Thanks in advance.
:Leon
Maybe we can figure it out without the schematic? Where is the cap connected?
Radios often have a cap across the AC line. They blow. The original is sometimes .05 mfd @ 400 volts. Use .01 mfd @ 600 volts if it's blown. Exact value isn't critical.
Electrolytic filter caps can also blow. If your radio is AC/DC, tubes with filaments wired in series, replace filters with 33 mfd @ 160 volt caps. Similar values would have been used in a radio with tubes like 35Z5, 35W4, 50L6, 35L6, 50B5, 50C5.
::Norm,
:Thanks for the schematic but unfortunately it's not the right one. This f-25 is a 5 tube model, in the shape of a cube, has the speaker mounted on the bottom facing the bottom and also has a clock in it. It is AM only without pushbuttons. I have seen pictures of it on the net but that is all.
:Thanks.
:Leon
:Hi Leon
:: Here is a 25. See if this matches?
::http://ww3.nostalgiaair.org/schematics/CRO/_CRO_12-17.gif
:::I have a Crosley F-25 that blew a cap but I don't know what the value of that cap is. I am looking for a set of schematics for this if anyone has a set. Can anyone help?
:::Thanks in advance.
:::Leon
Leon
: Maybe we can figure it out without the schematic? Where is the cap connected?
: Radios often have a cap across the AC line. They blow. The original is sometimes .05 mfd @ 400 volts. Use .01 mfd @ 600 volts if it's blown. Exact value isn't critical.
: Electrolytic filter caps can also blow. If your radio is AC/DC, tubes with filaments wired in series, replace filters with 33 mfd @ 160 volt caps. Similar values would have been used in a radio with tubes like 35Z5, 35W4, 50L6, 35L6, 50B5, 50C5.
:::Norm,
::Thanks for the schematic but unfortunately it's not the right one. This f-25 is a 5 tube model, in the shape of a cube, has the speaker mounted on the bottom facing the bottom and also has a clock in it. It is AM only without pushbuttons. I have seen pictures of it on the net but that is all.
::Thanks.
::Leon
::Hi Leon
::: Here is a 25. See if this matches?
:::http://ww3.nostalgiaair.org/schematics/CRO/_CRO_12-17.gif
::::I have a Crosley F-25 that blew a cap but I don't know what the value of that cap is. I am looking for a set of schematics for this if anyone has a set. Can anyone help?
::::Thanks in advance.
::::Leon
:Thanks in advance.
:Leon
