makes noise but won't play
11/23/2002 6:57:45 PMMark
I have a Philco 40-135 radio. I've replaced all of the tubes and now it makes a fast clicking noise. the speed if the clicking/popping noise changes VERY slightly with the volume controle. I have replaced the wires that were in really bad shape, and checked the air core cap/tuner. anyone have any ideas?
11/24/2002 2:46:24 AMsean nelson
:Sounds like you have something oscillating. Are the replacement tubes new and test good? Have you checked tube voltages at the pins of the tubes? Could also have some bad capacitors.
:I have a Philco 40-135 radio. I've replaced all of the tubes and now it makes a fast clicking noise. the speed if the clicking/popping noise changes VERY slightly with the volume controle. I have replaced the wires that were in really bad shape, and checked the air core cap/tuner. anyone have any ideas?
11/24/2002 2:46:53 AMsean nelson
:Sounds like you have something oscillating. Are the replacement tubes new and test good? Have you checked tube voltages at the pins of the tubes? Could also have some bad capacitors. I have a schematic of it if you need it.
11/24/2002 3:07:23 PMMark Sowles
I've looked for a schematic and can't find one. That would be great if you could email it to me. My email is msowles@kc.rr.com Thanks!
::Sounds like you have something oscillating. Are the replacement tubes new and test good? Have you checked tube voltages at the pins of the tubes? Could also have some bad capacitors. I have a schematic of it if you need it.
::I have a Philco 40-135 radio. I've replaced all of the tubes and now it makes a fast clicking noise. the speed if the clicking/popping noise changes VERY slightly with the volume controle. I have replaced the wires that were in really bad shape, and checked the air core cap/tuner. anyone have any ideas?
