Sent you a schematic. Hope it's a little better?
Pin #6 isn't used for the tube and would only be a tie point. Tie points are not called out in schematics.
:Tried to get info off nostalgiaair diagram not very clear .Off 35z5 Pin 2 there Are two units what appear to be a resistor and a cap going to pin 5 and another unit which appears to be a 2W resistor going from pin 2 to pin 6 Cant read all are burnt Thank Youfor the help Tom
::Hi Tom
:: Sent you a schematic. Hope it's a little better?
:: Pin #6 isn't used for the tube and would only be a tie point. Tie points are not called out in schematics.
::Thank You Norm
:::Tried to get info off nostalgiaair diagram not very clear .Off 35z5 Pin 2 there Are two units what appear to be a resistor and a cap going to pin 5 and another unit which appears to be a 2W resistor going from pin 2 to pin 6 Cant read all are burnt Thank Youfor the help Tom
:Hi, I have a similar problem. Cannot find a 100.364-1 chassis schematic. Could someone share? Thanks, Dave
