Admiral RC 200
11/10/2002 11:14:08 PMSusan
I own an Admiral RC200 short wave radio with a deluxe record changer (78 rpm/RMA No. 101 Serial # 21378). I am trying to find a needle for the record player. I believe this is called a sylus - the type you insert and tighten via a small screw in the front. Please suggest where I can find the needle.
11/11/2002 10:40:23 AMNorm Leal
Hi Susan
Here are a couple places to try: West Tech Services 931-424-1212 and Vintage Electronics 601-264-4755. There are others.
You may also need to replace the cartridge. They can help if needed.
:I own an Admiral RC200 short wave radio with a deluxe record changer (78 rpm/RMA No. 101 Serial # 21378). I am trying to find a needle for the record player. I believe this is called a sylus - the type you insert and tighten via a small screw in the front. Please suggest where I can find the needle.
