Driver transformer
11/1/2002 2:43:20 PMBobby Geoffroy
Just started on this set, while checking major componets located open winding on the driver transformer from plates of 6C5's. I used resistor and cap as temp to check out set and plays OK.
The set is RCA C11-3 Riders 6-115, would AES part # P-T156 work as replacement. Checked in trans manual and list 3.1 ratio 70K-7.7K for circuits using 6C5's as audio and driver and 6F6's as outputs, can't find anything to meet those specs. Any ideas on what transformer to use would be appreciated.
11/1/2002 5:12:56 PMNorm Leal
Hi Bobby
There will be a lot of gain using P-T156. Too bad it can't be used in reverse but you need a center tapped secondary.
Here is the problem. Your radio has two 6C5 stages before the 6F6's giving a lot of gain. The original transformer was 3:1 to reduce gain while PT156 is 1:3, increases gain.
You could use P-T124E but it is more expensive. This transformer has a center tap on primary & secondary which makes it usable in either direction.
: Hi,
: Just started on this set, while checking major componets located open winding on the driver transformer from plates of 6C5's. I used resistor and cap as temp to check out set and plays OK.
: The set is RCA C11-3 Riders 6-115, would AES part # P-T156 work as replacement. Checked in trans manual and list 3.1 ratio 70K-7.7K for circuits using 6C5's as audio and driver and 6F6's as outputs, can't find anything to meet those specs. Any ideas on what transformer to use would be appreciated.
