Those tube numbers weren't used in the US. Maybe radio hardware was made in US? Nice radio with double conversion.
Couldn't find Pullman is UK or German schematics that I have. Might try contacting Paul Stenning. He may be able to identify your radio?
http://www.vintage-radio.com/index.shtml
:Can any of you help me restore an unusual monster radio?
:I'm in the UKand bought this radio on eBay simply because I liked it's size & looks, and I want to restore it for personal use.
:The radio is unusual in that firstly it contains 10 valves incl. the rectifier and magic eye, with 9 on the main deck and a further 1 in a separate push-button tuner unit.
:The second oddity is that whilst the valves are all Mullard, the capacitors are a mixture of Austrian (SATOR) and British (Hunts).
:A further anomaly is that the fascia metal surround has "made in the United States of America" stamped into as a mirror image on the reverse side - it does not show on the visible side.
:The valve line up is:
:FC4 in separate tuner; TH4; VP4B;VP4B; DD4; 354V; AC044; AC044, R14; EM1.
:I'm not sure if the FC4 is used only with pre-selectors and the TH4 for manual tuning, or if the radio employs double conversion. I've not had time to work that out yet. It is clearly push-pull output the 354V driving a small transformer and subsequently the 2 AC044's.
:The radio also has variable bandwidth /selectivity, achieved through a combination of top-cut tone control ganged via a drive cord with cams that alter the coupling in the IF transformers!!!
:Any data or circuit or history would be of immense interest and help. I'm willing to pay for circuits etc.
:Best regards,
:Colin
If it is the same company, you might find out something at www.pullman.org
Otherwise maybe perusing court cases of 1930 through 1932 might reveal at least a little history if Pullman Palace Car was as protective of their identity over there as they were in the US.
It is a longshot, but it may be worth a try if you are really doing serious research.
:Hi Colin
: Those tube numbers weren't used in the US. Maybe radio hardware was made in US? Nice radio with double conversion.
: Couldn't find Pullman is UK or German schematics that I have. Might try contacting Paul Stenning. He may be able to identify your radio?
: http://www.vintage-radio.com/index.shtml
::Can any of you help me restore an unusual monster radio?
::I'm in the UKand bought this radio on eBay simply because I liked it's size & looks, and I want to restore it for personal use.
::The radio is unusual in that firstly it contains 10 valves incl. the rectifier and magic eye, with 9 on the main deck and a further 1 in a separate push-button tuner unit.
::The second oddity is that whilst the valves are all Mullard, the capacitors are a mixture of Austrian (SATOR) and British (Hunts).
::A further anomaly is that the fascia metal surround has "made in the United States of America" stamped into as a mirror image on the reverse side - it does not show on the visible side.
::The valve line up is:
::FC4 in separate tuner; TH4; VP4B;VP4B; DD4; 354V; AC044; AC044, R14; EM1.
::I'm not sure if the FC4 is used only with pre-selectors and the TH4 for manual tuning, or if the radio employs double conversion. I've not had time to work that out yet. It is clearly push-pull output the 354V driving a small transformer and subsequently the 2 AC044's.
::The radio also has variable bandwidth /selectivity, achieved through a combination of top-cut tone control ganged via a drive cord with cams that alter the coupling in the IF transformers!!!
::Any data or circuit or history would be of immense interest and help. I'm willing to pay for circuits etc.
::Best regards,
::Colin
