battery operated radio philco 38-123
10/28/2002 11:16:32 PMsean nelson
do these radios have poor sound quality I.E. distortion, or are they supposed to sound just like their A.C. counterparts. Not sure how they are supposed to sound. I am also wondering how clean the power supply ripple should be...maybe this could be causing the distorted sound
10/29/2002 9:11:09 AMNorm Leal
Hi Sean
Battery radios will distort at higher volume. Output tubes in these radios are rated around .25 watts. Look up the output tube in a manual to find your tube's ratings.
Check caps for leakage if the radio distorts at lower volume. Grid #1 bias on audio tubes can cause distortion with improper voltage.
:do these radios have poor sound quality I.E. distortion, or are they supposed to sound just like their A.C. counterparts. Not sure how they are supposed to sound. I am also wondering how clean the power supply ripple should be...maybe this could be causing the distorted sound
10/29/2002 10:57:29 AMJohn McPherson
The power supply ripple on the filaments is more noticable with some tubes(most octals for battery use, and a few locktals too) than others, but as a general rule, the cleaner DC you can supply to the radio, the better.
Unlike the first AC tubes that used filaments, most of the battery tubes used a filament that warmed up fast, but also cooled fast enough to affect emission, so you hear the hum.
If you make your supply as a full wave, rather than half wave rectification, you can reduce a certain amount of the hum.
:Hi Sean
: Battery radios will distort at higher volume. Output tubes in these radios are rated around .25 watts. Look up the output tube in a manual to find your tube's ratings.
: Check caps for leakage if the radio distorts at lower volume. Grid #1 bias on audio tubes can cause distortion with improper voltage.
::do these radios have poor sound quality I.E. distortion, or are they supposed to sound just like their A.C. counterparts. Not sure how they are supposed to sound. I am also wondering how clean the power supply ripple should be...maybe this could be causing the distorted sound
