PHILCO MODEL 80 SCHEMATIC
10/26/2002 9:50:45 PMSEAN NELSON
JUST BOUGHT A philco 80....no hum no nothing except tubes light up and one tube is shaped like a light bulb with no numbers on it(tube says philco on the bakelite)
10/26/2002 10:21:41 PMSEAN NELSON
:just thought a email address would help
:JUST BOUGHT A philco 80....no hum no nothing except tubes light up and one tube is shaped like a light bulb with no numbers on it(tube says philco on the bakelite)
10/26/2002 10:25:50 PMNorm Leal
Hi Sean
Philco schematic and other information can be found at:
http://www.nostalgiaair.org/Riders/PHL.htm
How many pins does your light bulb tube have? If 4 it's a 280. If 6 pins and no top cap it will be a 42.
10/26/2002 10:28:59 PMsaen nelson
:It has 6 pins on the light bulb tube. Other tubes are an 80 and two 36's
:Hi Sean
: Philco schematic and other information can be found at:
:http://www.nostalgiaair.org/Riders/PHL.htm
: How many pins does your light bulb tube have? If 4 it's a 280. If 6 pins and no top cap it will be a 42.
::JUST BOUGHT A philco 80....no hum no nothing except tubes light up and one tube is shaped like a light bulb with no numbers on it(tube says philco on the bakelite)
10/26/2002 10:36:58 PMsean nelson
:light bulb tube doesn't have a grid cap. The radio tube manual(from AES) says a 42 looks like an st tube according to their max view size. My tube gets continually wider at the top of the bakelite base until it curves over just like a light bulb
:Hi Sean
10/26/2002 10:37:16 PMsean nelson
:Hi Sean
10/26/2002 10:47:32 PMNorm Leal
Hi Sean
Believe Philco was the only manufacturer to use globe shaped 42's. AES will sell them used but have "call" for a price. This usually means they don't have any. You may want to use another, more modern, 42 tube while testing your Philco 80.
The were listed for $45, used a few years ago.
::light bulb tube doesn't have a grid cap. The radio tube manual(from AES) says a 42 looks like an st tube according to their max view size. My tube gets continually wider at the top of the bakelite base until it curves over just like a light bulb
::Hi Sean
:: Philco schematic and other information can be found at:
::http://www.nostalgiaair.org/Riders/PHL.htm
:: How many pins does your light bulb tube have? If 4 it's a 280. If 6 pins and no top cap it will be a 42.
:::JUST BOUGHT A philco 80....no hum no nothing except tubes light up and one tube is shaped like a light bulb with no numbers on it(tube says philco on the bakelite)
10/26/2002 10:48:37 PMsean nelson
:should I test this tube as a 42?
:Hi Sean
10/26/2002 10:51:35 PMNorm Leal
Yes, it is a 42, just older style and more valuable. Don't throw it out even if it's weak.
::should I test this tube as a 42?
::Hi Sean
10/26/2002 11:00:16 PMsean nelson
:just tested it...reads 20% and seems to stop at about 15%.....is that just about dead for an output tube?...could be my whole problem?
:Yes, it is a 42, just older style and more valuable. Don't throw it out even if it's weak.
:::should I test this tube as a 42?
:::Hi Sean
::: Philco schematic and other information can be found at:
:::http://www.nostalgiaair.org/Riders/PHL.htm
::: How many pins does your light bulb tube have? If 4 it's a 280. If 6 pins and no top cap it will be a 42.
::::JUST BOUGHT A philco 80....no hum no nothing except tubes light up and one tube is shaped like a light bulb with no numbers on it(tube says philco on the bakelite)
10/27/2002 12:24:35 AMNorm Leal
As long as your 42 has some emission it wouldn't prevent you from hearing sound. You could try another 41 or 42 tube.
Measure B+ voltage. Pin #2 & #3 on your 42 should both be positive. Pin #4 about 15 volts negative when measured from pin #5.
::just tested it...reads 20% and seems to stop at about 15%.....is that just about dead for an output tube?...could be my whole problem?
::Yes, it is a 42, just older style and more valuable. Don't throw it out even if it's weak.
::::should I test this tube as a 42?
::::Hi Sean
:::: Philco schematic and other information can be found at:
::::http://www.nostalgiaair.org/Riders/PHL.htm
:::: How many pins does your light bulb tube have? If 4 it's a 280. If 6 pins and no top cap it will be a 42.
::::Norm
:::::JUST BOUGHT A philco 80....no hum no nothing except tubes light up and one tube is shaped like a light bulb with no numbers on it(tube says philco on the bakelite)
10/27/2002 11:01:02 PMsean nelson
:The radio lives!.....wiggled tubes...gave it a good length of wire, BLEW OUT THE TUNER,(50 YEARS OF CRUD), BENT BACK TUNER FINS. CLEANED out pot, screwed in loose dial lamp, glued torn speaker, soldered on new grid wire on 1st 3 tube..and listin to it now,,..very good sound...I probably should order another 42 tube and save the 42 light bulb tube
:As long as your 42 has some emission it wouldn't prevent you from hearing sound. You could try another 41 or 42 tube.
:Measure B+ voltage. Pin #2 & #3 on your 42 should both be positive. Pin #4 about 15 volts negative when measured from pin #5.
:::just tested it...reads 20% and seems to stop at about 15%.....is that just about dead for an output tube?...could be my whole problem?
:::Yes, it is a 42, just older style and more valuable. Don't throw it out even if it's weak.
:::::should I test this tube as a 42?
:::::Hi Sean
::::: Philco schematic and other information can be found at:
:::::http://www.nostalgiaair.org/Riders/PHL.htm
::::: How many pins does your light bulb tube have? If 4 it's a 280. If 6 pins and no top cap it will be a 42.
:::::Norm
::::::JUST BOUGHT A philco 80....no hum no nothing except tubes light up and one tube is shaped like a light bulb with no numbers on it(tube says philco on the bakelite)
