:How can a 32 tube that tests at 14% and falling still work in a philco 38-123....tested by my triplet 3413. I also tested the 32 that is normally in the radio to see if it tested the same and it is at 82%
Try increasing filament voltage slightly on your tube tester. A weak 32 tube at 2 volts may be 100% with 2.5 volts on the filament. Not all stages require perfect tubes.. Final test of a tube should be the actual circuit.
You will find some cases just the opposite. A tube testing good won't work. This is sometimes the case with oscillators and TV tubes.
