Otherwise if you can locate the pot without a switch, find the manufacturer of the pot, and you can get a switch to install onto the back- Usually by unbending the ears that hold the metal cover on, and replacing that metal cover.
:anybody know where to get a 15k ohm linear pot with a switch
Another possible source is Gary Schneider at "Playthings of the Past":
www.oldradioparts.com
::Hi,
::AES (www.tubesandmore.com) and the radio junkyard (www.radiojunkyard.com)
::Otherwise if you can locate the pot without a switch, find the manufacturer of the pot, and you can get a switch to install onto the back- Usually by unbending the ears that hold the metal cover on, and replacing that metal cover.
:::anybody know where to get a 15k ohm linear pot with a switch
::the www.radiojunkyard.com doesnt work or seems to not work
