Rich
Have you tried putting the tube in the freezer for a few minutes so it becomes cold enought to get condensation on the envelope? If not, give it a try, as this should reveal a faint ghost of the old markings. I am assuming you have already tried to fog the tube by breathing on it, the freezer approach keeps the condensation fine enough to discern writing for a longer period.
:I have an old triode, 4-pin base, marked: "RCA Radiotron" and "US Navy CRC38064" on the
:bakelite base. I suspect it is equivalent to an 864, but would like
:confirmation. It's in a 2-tube Doerle type home-made regen receiver. The other
:tube is a 30. I've been using 1.5 V for the filaments, which is too low for the 30,
:and would be slightly high for the 864.
:Rich
Rich
:Hi,
:The CRC number is the contract number if I remember correctly. It should have a "VT" number, which was how the Navy and Army identified most tubes, or at least tried to.
:Have you tried putting the tube in the freezer for a few minutes so it becomes cold enought to get condensation on the envelope? If not, give it a try, as this should reveal a faint ghost of the old markings. I am assuming you have already tried to fog the tube by breathing on it, the freezer approach keeps the condensation fine enough to discern writing for a longer period.
::I have an old triode, 4-pin base, marked: "RCA Radiotron" and "US Navy CRC38064" on the
::bakelite base. I suspect it is equivalent to an 864, but would like
::confirmation. It's in a 2-tube Doerle type home-made regen receiver. The other
::tube is a 30. I've been using 1.5 V for the filaments, which is too low for the 30,
::and would be slightly high for the 864.
::Rich
I have an 864, marked on the glass, with U.S. Navy, CRC 38064 engraved into the base. Your tube is an 864.
Normm
:I did try the fog method, but could see only a "4" etched on the glass envelope.
:No VT- number visible. I have a good list of VT data. I will try the freezer method.
:Tnx...
:Rich
::Hi,
::The CRC number is the contract number if I remember correctly. It should have a "VT" number, which was how the Navy and Army identified most tubes, or at least tried to.
::Have you tried putting the tube in the freezer for a few minutes so it becomes cold enought to get condensation on the envelope? If not, give it a try, as this should reveal a faint ghost of the old markings. I am assuming you have already tried to fog the tube by breathing on it, the freezer approach keeps the condensation fine enough to discern writing for a longer period.
:::I have an old triode, 4-pin base, marked: "RCA Radiotron" and "US Navy CRC38064" on the
:::bakelite base. I suspect it is equivalent to an 864, but would like
:::confirmation. It's in a 2-tube Doerle type home-made regen receiver. The other
:::tube is a 30. I've been using 1.5 V for the filaments, which is too low for the 30,
:::and would be slightly high for the 864.
:::Rich
Rich
:Hi Rich
: I have an 864, marked on the glass, with U.S. Navy, CRC 38064 engraved into the base. Your tube is an 864.
:Normm
::I did try the fog method, but could see only a "4" etched on the glass envelope.
::No VT- number visible. I have a good list of VT data. I will try the freezer method.
::Tnx...
::Rich
:::Hi,
:::The CRC number is the contract number if I remember correctly. It should have a "VT" number, which was how the Navy and Army identified most tubes, or at least tried to.
:::Have you tried putting the tube in the freezer for a few minutes so it becomes cold enought to get condensation on the envelope? If not, give it a try, as this should reveal a faint ghost of the old markings. I am assuming you have already tried to fog the tube by breathing on it, the freezer approach keeps the condensation fine enough to discern writing for a longer period.
::::I have an old triode, 4-pin base, marked: "RCA Radiotron" and "US Navy CRC38064" on the
::::bakelite base. I suspect it is equivalent to an 864, but would like
::::confirmation. It's in a 2-tube Doerle type home-made regen receiver. The other
::::tube is a 30. I've been using 1.5 V for the filaments, which is too low for the 30,
::::and would be slightly high for the 864.
::::Rich
