Just recapped philco 40-130...
9/14/2002 4:16:35 PMBobby Brown
After recapping and testing the tubes (they are good), I powered up the radio and only get a low hum from the speaker. The radio didn't work previously. I have the original antenna from the back of the radio hooked up. The volume does adjust the speaker hum. What can I test to see if the radio is picking up any stations? Any help will be greatly appreciated.
Thanks.
Bobby Brown
9/14/2002 6:09:50 PMNorm Leal
Hi Bobby
The audio section of your radio is working if hum varies with volume control. (Tubes 7C6 & 7B5.)
Check voltages on plate & screen of 7C7, 7A8 and 7B7. Pin #4 of your 7A8 should be a few volts negative if the oscillator is operating. If it's not negative check continuity of coil #17 in the schematic. Oscillator coils sometime open in Philco radios.
:After recapping and testing the tubes (they are good), I powered up the radio and only get a low hum from the speaker. The radio didn't work previously. I have the original antenna from the back of the radio hooked up. The volume does adjust the speaker hum. What can I test to see if the radio is picking up any stations? Any help will be greatly appreciated.
:Thanks.
:Bobby Brown
