Measure your output tube grid #1 voltage in relation to cathode. It must be several volts negative. If positive there will be distortion and excessive current drawn.
The problem will usually be a leaky coupling cap to grid #1. An open grid resistor or bad output tube can also cause the problem. It gets worse as tubes heat.
:I purchased this in really bad shape. I have fixed the cracks repainted and recapped the unit. My problem is that after 10-15 minutes of play the output becomes distorted. It is almost like when tuning a station you just are not quite on it, but when first turned on it plays great. I looked for the schm. but could not find it. Can it be that when I test the tubes I will need to leave them in for approx 10 min if a tube is the problem. Please help. thank you, Peter
:Hi Peter
: Measure your output tube grid #1 voltage in relation to cathode. It must be several volts negative. If positive there will be distortion and excessive current drawn.
: The problem will usually be a leaky coupling cap to grid #1. An open grid resistor or bad output tube can also cause the problem. It gets worse as tubes heat.
::I purchased this in really bad shape. I have fixed the cracks repainted and recapped the unit. My problem is that after 10-15 minutes of play the output becomes distorted. It is almost like when tuning a station you just are not quite on it, but when first turned on it plays great. I looked for the schm. but could not find it. Can it be that when I test the tubes I will need to leave them in for approx 10 min if a tube is the problem. Please help. thank you, Peter
