RME 45 comunications reciever
9/10/2002 11:27:46 PMsteve
Im currently restoring an rme 45, the set is mostly original but with some modifications. what I need is a detailed scematic stateing the resistor and capacitor values and hopefully the required voltages throughout the circut. the set does work but I would like to see it back to original opperating condition. any help is appreciated.
9/11/2002 1:40:32 PMJohn McPherson
Have opened the reciever up yet?
Many times there is a schematic with the component values inside the unit to aid field repairs.
If yours does not, you might post a query on the QTH list www.qth.org
:Im currently restoring an rme 45, the set is mostly original but with some modifications. what I need is a detailed scematic stateing the resistor and capacitor values and hopefully the required voltages throughout the circut. the set does work but I would like to see it back to original opperating condition. any help is appreciated.
9/11/2002 4:20:29 PMNorm Leal
Hi
If you don't find what you need inside check the following site:
ftp://bama.sbc.edu/downloads/rme/rme45/
:Hi,
:Have opened the reciever up yet?
:Many times there is a schematic with the component values inside the unit to aid field repairs.
:If yours does not, you might post a query on the QTH list www.qth.org
::Im currently restoring an rme 45, the set is mostly original but with some modifications. what I need is a detailed scematic stateing the resistor and capacitor values and hopefully the required voltages throughout the circut. the set does work but I would like to see it back to original opperating condition. any help is appreciated.
10/7/2002 9:26:32 PMsteve
:Hi
: If you don't find what you need inside check the following site:
:ftp://bama.sbc.edu/downloads/rme/rme45/
::Hi,
::Have opened the reciever up yet?
::Many times there is a schematic with the component values inside the unit to aid field repairs.
::If yours does not, you might post a query on the QTH list www.qth.org
:::Im currently restoring an rme 45, the set is mostly original but with some modifications. what I need is a detailed scematic stateing the resistor and capacitor values and hopefully the required voltages throughout the circut. the set does work but I would like to see it back to original opperating condition. any help is appreciated.
10/7/2002 9:38:06 PMsteve
::Hi, thanks for the reply, bama is helpfull but i still need the voltages ie 1st, 2nd if's, and resistor values. some of the existing componets are not original thus a resistor with bands reading 30k measures 8k is typical and throwing the bias voltages off and i suspect that the original value was between 2-4k, experimentation within these values has brought the reciever back to life. i will post a message when I complete the restoration, thanks again, steve.
:: If you don't find what you need inside check the following site:
::ftp://bama.sbc.edu/downloads/rme/rme45/
:::Hi,
:::Have opened the reciever up yet?
:::Many times there is a schematic with the component values inside the unit to aid field repairs.
:::If yours does not, you might post a query on the QTH list www.qth.org
::::Im currently restoring an rme 45, the set is mostly original but with some modifications. what I need is a detailed scematic stateing the resistor and capacitor values and hopefully the required voltages throughout the circut. the set does work but I would like to see it back to original opperating condition. any help is appreciated.
