Magnet recharging
9/8/2002 5:28:15 PMEric Morritt
I read the "how to" on recharging speaker magnets in the tech tip section of Nostalgiaair, and tried it with a horseshoe speaker magnet, but instead of remagnetizing it, it took what was left of any magnetic "pull" away. Anybody have any ideas what I did wrong?
Thanks!
9/9/2002 9:56:29 AMJohn McPherson
Chances are good that you magnetized it, but rather than the poles being at the ends of the horseshoe, you magnetized the poles across the thickness. You litterally need to remove the magnet and run the charging magnet from one pole end to the other. Also be sure to use just one pole of the charging magnet, otherwise you undo some of the magnetization that you just did.
:I read the "how to" on recharging speaker magnets in the tech tip section of Nostalgiaair, and tried it with a horseshoe speaker magnet, but instead of remagnetizing it, it took what was left of any magnetic "pull" away. Anybody have any ideas what I did wrong?
:Thanks!
