Philco 46-480
9/3/2002 10:18:13 PMRoland Phillips
I need the RF/IF section of the schematic for a Philco 46-480. I got the detector and output section off this site. Thanks again. If anyone can help, thanks in advance.
9/3/2002 11:14:28 PMJohn McPherson
Go back to that page and as the image loads, or after it has loaded, click on image to get the larger view.
When you have the larger view, look up at your location window, and you will see the url, the "Philco _13-24..." is the page you are on for example, now edit that location to "Philco_13-25...", or whatever would be the next page. You should also find specific allignment instructions too on succeeding pages.
: I need the RF/IF section of the schematic for a Philco 46-480. I got the detector and output section off this site. Thanks again. If anyone can help, thanks in advance.
9/4/2002 10:04:46 PMRoland Phillips
Thanks once again.
:Hi,
:Go back to that page and as the image loads, or after it has loaded, click on image to get the larger view.
:When you have the larger view, look up at your location window, and you will see the url, the "Philco _13-24..." is the page you are on for example, now edit that location to "Philco_13-25...", or whatever would be the next page. You should also find specific allignment instructions too on succeeding pages.
:: I need the RF/IF section of the schematic for a Philco 46-480. I got the detector and output section off this site. Thanks again. If anyone can help, thanks in advance.
9/5/2002 9:44:24 AMPoston Drake
Roland,
Hope you got what you needed for your Philco. If not, I have the original Philco Service bulletin for the model 46-480; it is 12 pages long and contains a lot more service info than Rider's. I don't have a scanner, but could send you a copy via regular mail. If you are interested, send me an email.
