Tranformer Help for Philco Model 90
8/1/2002 6:15:51 PMJoe Miller
I have a Philco model 90 (good set). I found the 1st detector transformer with an open winding. I can't repair it. Anyone know where I can get a replacement (its part number 03015).
I am also thinking of rewinding it but the replacement wire I have is a slightly larger guage. Will it work if I use the same number of turns? The current winding is one level and I may have to overlap it with a few windings of the larger replacement wire. Any tips on rewinding would be appreciated.
8/1/2002 7:26:26 PMNorm Leal
Hi Joe
AES, tubesandmore.com and Play Things Of Past, oldradioparts.com should both have replacements.
The following address has a list of coils available from Play Things Of Past.
http://www.oldradioparts.com/2a6fla.txt
You could rewind the coil but it has to track with antenna & oscillator coils. Only the secondary is critical. It's part of a tuned circuit. If it isn't close ends of the band won't align properly. The primary is used for coupling and not critical as to number of turns.
:I have a Philco model 90 (good set). I found the 1st detector transformer with an open winding. I can't repair it. Anyone know where I can get a replacement (its part number 03015).
:I am also thinking of rewinding it but the replacement wire I have is a slightly larger guage. Will it work if I use the same number of turns? The current winding is one level and I may have to overlap it with a few windings of the larger replacement wire. Any tips on rewinding would be appreciated.
8/2/2002 7:07:04 PMJoe Miller
I rewound the coil and the radio works fine..thanks for you help (again)
Joe
Hi Joe
: AES, tubesandmore.com and Play Things Of Past, oldradioparts.com should both have replacements.
: The following address has a list of coils available from Play Things Of Past.
: http://www.oldradioparts.com/2a6fla.txt
: You could rewind the coil but it has to track with antenna & oscillator coils. Only the secondary is critical. It's part of a tuned circuit. If it isn't close ends of the band won't align properly. The primary is used for coupling and not critical as to number of turns.
::I have a Philco model 90 (good set). I found the 1st detector transformer with an open winding. I can't repair it. Anyone know where I can get a replacement (its part number 03015).
::I am also thinking of rewinding it but the replacement wire I have is a slightly larger guage. Will it work if I use the same number of turns? The current winding is one level and I may have to overlap it with a few windings of the larger replacement wire. Any tips on rewinding would be appreciated.
