Thanks in advance.
Mark
You could try a spray on product like K2r, where you spray it on, and let it dry, then gently brush it off. Otherwise, most water type stains are the result of minerals,dirt, and dyes that were left behind when the water evaporated. If it is tobbacco smoke stanis, the K2r is about it, but you could try a chlorinated solvent such as brake cleaner, or contact cleaner.
The other problem is evening out the appearance.
:I have a radio that has very nice grille cloth, not ripped or stretched and it is still attached to the cardboard. The only problem is that it is stained. Anyone have any tips on cleaning the cloth (it appears to be rayon) without damaging it?
:Thanks in advance.
:Mark
Joe
:Thanks in advance.
:Mark
