Harmon Kardon 430... sound out of left but no right
7/9/2002 7:40:53 PMChris
I was setting it up and from some reason can't get sound out of the right speakers on either system 1 or 2. I thought it might be the fuse but it wasn't. I moved the balance and that wasn't it either... I know the speakers are fine so I'm a little perplexed. Do you know what could possibly be causing me to lose all sound out of the right speakers? I would really appreciate any thoughts.
Much Obliged
Chris
7/10/2002 8:57:32 AMJohn McPherson
The finals may be dead, or the cap on the output may have opened up. It is possible too that if you were listening to FM only, and did not compare it to Phono, Tape, Aux, or AM, that it might have been a failed FM demodulator.
:I was setting it up and from some reason can't get sound out of the right speakers on either system 1 or 2. I thought it might be the fuse but it wasn't. I moved the balance and that wasn't it either... I know the speakers are fine so I'm a little perplexed. Do you know what could possibly be causing me to lose all sound out of the right speakers? I would really appreciate any thoughts.
:Much Obliged
:Chris
7/10/2002 10:54:28 AMChris
I have only listened to FM through the receiver... I'll try what you suggested... thanks a lot!
Take Care
C
3/1/2003 12:23:58 AMBill Hamilton
:I have only listened to FM through the receiver... I'll try what you suggested... thanks a lot!
:Take Care
:C Chris did you ever get the problem fixed? There is a guy HDBRbuiler on the Klipsch website. (2 channel) that loves these and is very knowledgeable. Luck bill
3/1/2003 12:21:22 AMw. hamilton
:Much Obliged
:Chris
