Bosch made a battery eliminator. The schematic is in Rider. Click on the schematic to get a larger copy. Didn't find Yale.
http://www.nostalgiaair.org/Riders/showinfo.asp?PATH=UAB&IMG=_UAB_1-1.gif&INF=BAN%20%20PWR%2E%20%20UNITS
If your resistors are wire wound they should be ok unless open. Filter capacitors should be replaced. The rectifier may also be weak. These supplies usually had 80 or BH tubes.
:I have a Yale BP-135 Automatic B - Battery Eliminator. The unit functions but the posts do not put out the correct voltages. There are 4 wire wound resistors inside. I believe they are the problem. Does anyone have info on this set or know the resistor values? I have been unable to find anything on this set. Any help would be appreciated.
:Thanks,
:Paul
Paul
:Hi Paul
: Bosch made a battery eliminator. The schematic is in Rider. Click on the schematic to get a larger copy. Didn't find Yale.
:http://www.nostalgiaair.org/Riders/showinfo.asp?PATH=UAB&IMG=_UAB_1-1.gif&INF=BAN%20%20PWR%2E%20%20UNITS
: If your resistors are wire wound they should be ok unless open. Filter capacitors should be replaced. The rectifier may also be weak. These supplies usually had 80 or BH tubes.
::I have a Yale BP-135 Automatic B - Battery Eliminator. The unit functions but the posts do not put out the correct voltages. There are 4 wire wound resistors inside. I believe they are the problem. Does anyone have info on this set or know the resistor values? I have been unable to find anything on this set. Any help would be appreciated.
::Thanks,
::Paul
:Thanks for the info Norm. The Bosch battery eliminators did not match the yale. I found that two of the four wire wound resistors were open. The 135 volt tap has no resistor, the 90Volt tap has a 8k ohm resistor, the 67 1/2 volt tap has 10k ohm rsistor, the 45V tap has an open resistor and the last resistor has no tap associated with it but is also open (may be for the supply because the other three share the same source voltage. You are right about changing the filter caps. I need the correct info for the unit to determine the values etc. Any other ideas or info sources would be much appreciated.
:Thanks for your assistance.
:Paul
::Hi Paul
:: Bosch made a battery eliminator. The schematic is in Rider. Click on the schematic to get a larger copy. Didn't find Yale.
::http://www.nostalgiaair.org/Riders/showinfo.asp?PATH=UAB&IMG=_UAB_1-1.gif&INF=BAN%20%20PWR%2E%20%20UNITS
:: If your resistors are wire wound they should be ok unless open. Filter capacitors should be replaced. The rectifier may also be weak. These supplies usually had 80 or BH tubes.
:::I have a Yale BP-135 Automatic B - Battery Eliminator. The unit functions but the posts do not put out the correct voltages. There are 4 wire wound resistors inside. I believe they are the problem. Does anyone have info on this set or know the resistor values? I have been unable to find anything on this set. Any help would be appreciated.
:::Thanks,
:::Paul
The caps will be low values, on the order of 2 Mfd, especially if there is a heavy choke in the unit. Replacing them with new capacitors of the same size will usually yield higher voltages overall.
I use Digi-key for caps. www.digikey.com
:Paul
::Hi Paul
:::Thanks,
:::Paul
