Shorted tubes
7/1/2002 5:13:44 PMJustin
Hi Guys
I have what most of you might call a dumb question, but here goes: How does a tube become shorted and what will it affect? Does it make the audio sound different? I just replaced the 6F6's in my RCA 811K because they tested shorted on my GE TC-3 tester. Thanks, Justin
7/1/2002 8:05:46 PMNorm Leal
Hi Justin
A tube becomes shorted when one element touches another. This condition can damage other components in your radio.
A short on a tube tester is generally leakage between elements. As tubes operate carbon is deposited on mica insulators, between elements. This gives a leakage path which can cause a tube to draw excessive current.
Depending on where this leakage is located it can cause hum or distorted sound. Some leakage paths will not effect sound quality.
:Hi Guys
: I have what most of you might call a dumb question, but here goes: How does a tube become shorted and what will it affect? Does it make the audio sound different? I just replaced the 6F6's in my RCA 811K because they tested shorted on my GE TC-3 tester. Thanks, Justin
7/9/2002 9:39:41 PMKurt
Measure If the first grid is Positive against the Kathode. It should be about minus 6 volts, if not the tube draws exesive currend. It also could be coused by a leaky coupling Capacitor, Kurt
:Hi Guys
