: I posted an earlier message with the wrong Model #. I just found a label on the chassis with the
: model # 04WG-1108. Its possible there was one more digit after the 8 because of a tear in the label, but its close to the edge so I don't think so. The tubes used are: one 6C6, two 6D6, one 6J5G, two 41, two 76, one 80, and a tuning eye 6U5. I have not been able to find this model in the schematics database, I think its a little newer than the models listed. Thank you for your help.
: Michael Johnson
: Hi Michael, I've sent the schematic for the Airline 04WG-1108A by email. I hopr this is the same as your set. Don.
: : I posted an earlier message with the wrong Model #. I just found a label on the chassis with the
: : model # 04WG-1108. Its possible there was one more digit after the 8 because of a tear in the label, but its close to the edge so I don't think so. The tubes used are: one 6C6, two 6D6, one 6J5G, two 41, two 76, one 80, and a tuning eye 6U5. I have not been able to find this model in the schematics database, I think its a little newer than the models listed. Thank you for your help.
: : Michael Johnson
Your radio is not listed in Rider. I believe you have the model number correct. The only thing that could be missing would be a letter after the last number. Several of us will be checking for a similar schematic.
A couple questions.. Was the radio built in the US? Canadian radios are different. Is there a 6A7 in the radio? It's hard to understand why your radio has a 6J5G and 76 tubes. They are similar electrically but the 76 is an earlier tube. Is there any sign that radio was modified and the 6J5G was added later?
: Michael Johnson
: A couple questions.. Was the radio built in the US? Canadian radios are different.
: Norm
: : Michael Johnson
