I hope you can help - I am looking for information regarding a electordynamic speaker for a FADA RW (133, 134, 135, 78-1, 79-10, 97-1).
I have found another number which reads RW 3083 (serial number?).
The radio is (half console - external speaker type?)known as a "Flash-o-graph" [as having a 4 contact flash-o-graph Tube type N4].
My problem is that I do not have information of the transformer or speaker - as I have to find a replacement/subsitute.
Is this a hard job to do?
I have six wires,color coded, that must lead to this transformer/speaker?
Your help is much appreciated and I look forward to hearing from you all and yes this is my 2nd restoration project - so I am green as they come!
All the best
JP
The output transformer should be 10,000 ohm impedance plate to plate @ 20 watts. Exact transformer rating isn't critical.
The winding between B+ and output transformer center tap isn't critical either. Use a 5-10 henry choke rated 100 ma or more. You may want to add a wire wound resistor in series if voltage is above tube ratings.
Final winding sets up bias on your 85 tube & Flash-O-Graph . Use a 5-10 henry choke @ 100 ma or greater. A wire wound resistor may be added in series. Notice the 500,000 & 50,000 ohm resistor at the bottom of your schematic. Changing these resistors adjusts bias on your 85 tube.
After all that, do you have a good Flash-O-Graph? Don't think I've seen one that wasn't black.
:Hi All
:I hope you can help - I am looking for information regarding a electordynamic speaker for a FADA RW (133, 134, 135, 78-1, 79-10, 97-1).
:I have found another number which reads RW 3083 (serial number?).
:The radio is (half console - external speaker type?)known as a "Flash-o-graph" [as having a 4 contact flash-o-graph Tube type N4].
:My problem is that I do not have information of the transformer or speaker - as I have to find a replacement/subsitute.
:Is this a hard job to do?
:I have six wires,color coded, that must lead to this transformer/speaker?
:Your help is much appreciated and I look forward to hearing from you all and yes this is my 2nd restoration project - so I am green as they come!
:All the best
:JP
I told you I was green!
And unfortunately my N-4 flash-o-graph tube is black too.
All the best JP
All the best JP
