If you are sure the knobs are bakelite paint remover will not damage them. Try a small spot first to be sure.
Bakelite can be tested by heating with a soldering iron or hot pin. Plastic will melt, bakelite will not.
If plastic, painted with latex paint, try soaking overnight in soapy water.
:Hi All,
: Does anyone know how to remove paint from bakelite? Somebody painted the knobs on one of my Arvin metal radios a God awful PINK. I don't want to try using paint remover because I know what it will do to the plastic.
:Take care and thanks
:Bud
:Hi Bud
: If you are sure the knobs are bakelite paint remover will not damage them. Try a small spot first to be sure.
: Bakelite can be tested by heating with a soldering iron or hot pin. Plastic will melt, bakelite will not.
: If plastic, painted with latex paint, try soaking overnight in soapy water.
::Hi All,
:: Does anyone know how to remove paint from bakelite? Somebody painted the knobs on one of my Arvin metal radios a God awful PINK. I don't want to try using paint remover because I know what it will do to the plastic.
::Take care and thanks
::Bud
If the knobs are a vinyl compound, they will melt also. Vinyl knobs flex a bit, and usually do not feel as dense.
:Hi Norm,
: Well, now that you mention it, no I am not sure whether they are Bakelite or not but I will sure give them a shot with the iron to test. They were the original knobs on this model 444 Arvin so I don't know if they are plastic or Bakelite. Let ya know later.
:Thanks
:Bud
::Hi Bud
:: If you are sure the knobs are bakelite paint remover will not damage them. Try a small spot first to be sure.
:: Bakelite can be tested by heating with a soldering iron or hot pin. Plastic will melt, bakelite will not.
:: If plastic, painted with latex paint, try soaking overnight in soapy water.
:::Hi All,
::: Does anyone know how to remove paint from bakelite? Somebody painted the knobs on one of my Arvin metal radios a God awful PINK. I don't want to try using paint remover because I know what it will do to the plastic.
:::Take care and thanks
:::Bud
:Hi,
:If the knobs are plastic or bakelite, often the paint will come off by letting them soak for a few days in DOT3 (polyethylene glycol). If it was a spray paint, or brush pant not from factory production, the old paint will usually come off over night. I have not tried it on factory production paint, butit should- it will take a few days though.
:If the knobs are a vinyl compound, they will melt also. Vinyl knobs flex a bit, and usually do not feel as dense.
::Hi Norm,
:: Well, now that you mention it, no I am not sure whether they are Bakelite or not but I will sure give them a shot with the iron to test. They were the original knobs on this model 444 Arvin so I don't know if they are plastic or Bakelite. Let ya know later.
::Thanks
::Bud
:::Hi Bud
::: If you are sure the knobs are bakelite paint remover will not damage them. Try a small spot first to be sure.
::: Bakelite can be tested by heating with a soldering iron or hot pin. Plastic will melt, bakelite will not.
::: If plastic, painted with latex paint, try soaking overnight in soapy water.
::::Hi All,
:::: Does anyone know how to remove paint from bakelite? Somebody painted the knobs on one of my Arvin metal radios a God awful PINK. I don't want to try using paint remover because I know what it will do to the plastic.
::::Take care and thanks
::::Bud
