sub for 12z3?
6/7/2002 3:54:13 PMMicahel
Anybody know if there is a substitute for the 12z3 tube?
6/7/2002 10:47:25 PMJohn McPherson
According to one of substitution books, they list a "14G3" Both are a 4 pin tube from their info.
:Anybody know if there is a substitute for the 12z3 tube?
6/8/2002 10:04:13 AMDon Black
Hi Michael, Is there any particular reason you're looking for a substitute? New 12Z3 tubes are readily available, ETC at http://members.aol.com/etetubes/ has them for $2.00 each and AES www,tubesandmore.com list them for $3.10 (I think they have a minimum order value at AES), plus postage.
Don Black.
:Hi,
:According to one of substitution books, they list a "14G3" Both are a 4 pin tube from their info.
::Anybody know if there is a substitute for the 12z3 tube?
6/8/2002 5:00:29 PMNorm Leal
Hi Michael
Use a 1V if your radio has series wired filaments. It's not rated as high in current but will work until you get a 12Z3.
Use can use a 1N4007 silicon diode. Banded end on a diode is cathode. With series wired filaments a 40 ohm 5 watt resistor is required between the two large pins.
:Hi Michael, Is there any particular reason you're looking for a substitute? New 12Z3 tubes are readily available, ETC at http://members.aol.com/etetubes/ has them for $2.00 each and AES www,tubesandmore.com list them for $3.10 (I think they have a minimum order value at AES), plus postage.
:Don Black.
::Hi,
::According to one of substitution books, they list a "14G3" Both are a 4 pin tube from their info.
:::Anybody know if there is a substitute for the 12z3 tube?
6/8/2002 11:26:03 PMMichael
Thank you guys... I asked because I don't have this tube on hand at the moment but I wanted to test the radio out..
I'll see if I have those tubes and diode around.
Michael
:Hi Michael
: Use a 1V if your radio has series wired filaments. It's not rated as high in current but will work until you get a 12Z3.
: Use can use a 1N4007 silicon diode. Banded end on a diode is cathode. With series wired filaments a 40 ohm 5 watt resistor is required between the two large pins.
::Hi Michael, Is there any particular reason you're looking for a substitute? New 12Z3 tubes are readily available, ETC at http://members.aol.com/etetubes/ has them for $2.00 each and AES www,tubesandmore.com list them for $3.10 (I think they have a minimum order value at AES), plus postage.
::Don Black.
:::Hi,
:::According to one of substitution books, they list a "14G3" Both are a 4 pin tube from their info.
::::Anybody know if there is a substitute for the 12z3 tube?
