In the 20's they did make high impedance speakers. 2000 ohms was common. Their tone quality was very poor. If you have high impedance the resistance is also high leading to poor frequency response.
The 45 ohm speakers are generally used for intercoms which do not require a wide frequency response.
: Since this is a "technical discussion" forum I would like to
: canvas the cyber for opinions as to why loudspeaker voice
: coils have traditionally been low impedences. The fact that
: they are low Z causes their current to be greater and their
: bobbin wire must be larger. Furthermore, the low Z load presented
: by these speakers makes power amplifier design more difficult and
: larger wire should be used to connect low Z speaker loads when
: the wire run is any distance. As we all know, it is not
: imposssible to manufacture 45 ohm speakers and even higher. If you will notice
: the marketplace, most auto premium speakers are 4 ohms with many musical
: instrument speakers down to 2 ohms. This seems like a
: bad electrical decisioin to me.
