Crosley new buddy
4/24/2002 8:54:33 PMDan
Greetings,
I have a burned 3rd stage coil. This radio uses 3 #24's. Is it possible to use a 3rd stage coil out of another radio that uses 3 #24's? The coils are similar in appearance but the windings are different. If they aren't directly interchangeable, is there a way to make it so? Anyone out there have one of these coils?
Thanx
Dan
4/25/2002 9:47:21 AMNorm Leal
Hi Dan
You will either need more or less capacity to make the coil track if it is different. Check Play Things of Past, oldradioparts.com . They have a long list of replacement coils. You might find one for your radio?
: Greetings,
: I have a burned 3rd stage coil. This radio uses 3 #24's. Is it possible to use a 3rd stage coil out of another radio that uses 3 #24's? The coils are similar in appearance but the windings are different. If they aren't directly interchangeable, is there a way to make it so? Anyone out there have one of these coils?
: Thanx
: Dan
4/25/2002 8:44:35 PMDan
: Hi Dan
: You will either need more or less capacity to make the coil track if it is different. Check Play Things of Past, oldradioparts.com . They have a long list of replacement coils. You might find one for your radio?
: Norm
: : Greetings,
: : I have a burned 3rd stage coil. This radio uses 3 #24's. Is it possible to use a 3rd stage coil out of another radio that uses 3 #24's? The coils are similar in appearance but the windings are different. If they aren't directly interchangeable, is there a way to make it so? Anyone out there have one of these coils?
: : Thanx
: : Dan
4/25/2002 8:47:58 PMDan
Norm,
Thank you for your suggestions.
Dan
