Information about the Philco 16 is in Rider Vol #4. To get this information go to nostalgiaair home page and click on Rider Vol #4. Then under Philco click on 4-3 and 4-4. This is information for your radio.
Certain rubber mounts and other parts for old radios are sold by Antique Electronic Supply, tubesandmore.com . For others you will need to locate similar parts in hardware stores.
There will be voltages in your radio to the 300 volt range. Hum is actually a good sign. The electrolytic filter capacitors need to be changed but the speaker should be ok. You can use 10 mfd @ 450 volt capacitors to replace the 8's in your radio. Watch the polarity when installing replacements.
Good luck..
: Hi,
: I have a Philco Model 16 radio. I have a few questions
: to ask about the Radio.
: How do I find a troubleshooting manual for the Radio?
: The rubber parts in the tuner section are needing
: to be replaced, is there a good source to find these parts?
: I have never worked on a tube type radio before
: are there areas of high
: voltage that I need to watch out for?
: Is this radio worth fixing?
: I powered the radio up using a variable
: transformer over a long period of time.
: The radio is just giving me a hum is this good or bad?
: Thanks for all replies Steve
This is DEFINITELY worth restoring.
Bob Rosengarten
