Kindly advise possible causes of loss of sync and negative picture.
Regards
Rabson Mhango
: I have just acquired this Grundig CTV, but has loss of both Vertical and Horizontal Synchronisation, also picture showing negative. Tried to change TDA2595 OSC. IC but no change. I have no circuit diagram for the same.
: Kindly advise possible causes of loss of sync and negative picture.
: Regards
: Rabson Mhango
: Regards
: Rabson Mhango
I have only the data sheet of the TDA2595. It is on my homepage under http://de.geocities.com/electronicfox2001/datasheet/TDA2595.pdf. Still different data sheets under www.electronicfox.at.tf.
