: Hello everyone
: I am from italy and I purchased a Magnavox R3D horn. The coils tests at 705 ohms the input, and 9.5 ohms the battery, and from my scarce information sources they should be the right values.
: Anyway the driver appears frozen and no sound from the horn.
: I think it is a mechanical trouble probably due to the driver diaphragm
: frozen for some reason (rust?).
: Before to open the base, in order to avoid some bad move, I need literatures
: or drawings from any kind of service manual related to this equipment.
: If someone can help me, please let me know.
: Obviously I will cover any kind of cost.
: Thank you in advance
: Regards
: Paolo Ghini
: Hello Paolo, I'm surprised no one's been able to answer your questions. I don't have one of these Magnavox drivers but I think I know someone who has. If it's what I'm thinking of it's a moving coil driver for a horn with a copper disk diaphram and 6 volt field coil. I'll try and contact the owner and find out some information. He might be away at present, he's elderly and as it's Winter here in Australia he often goes North where it's warm for a couple of Months. I'll let you know what I can find out. I also think I remember an article on the speaker, if I can find it I'll send it to you. Don Black.
: : Hello everyone
: : I am from italy and I purchased a Magnavox R3D horn. The coils tests at 705 ohms the input, and 9.5 ohms the battery, and from my scarce information sources they should be the right values.
: : Anyway the driver appears frozen and no sound from the horn.
: : I think it is a mechanical trouble probably due to the driver diaphragm
: : frozen for some reason (rust?).
: : Before to open the base, in order to avoid some bad move, I need literatures
: : or drawings from any kind of service manual related to this equipment.
: : If someone can help me, please let me know.
: : Obviously I will cover any kind of cost.
: : Thank you in advance
: : Regards
: : Paolo Ghini
