Wards Airline Superheterodyne schematic and power supply.
4/3/2001 3:04:37 PMGuido
I wish to restore a farm radio that I picked up few weeks ago. It is a Wards Airline Superheterodyne farm radio. I was told that it was a model 41 but I can not find a 41 listed anywhere.
It has 9 tubes. Three are 34's and six are 30's.
I will be making a power supply for it and it requires the following B voltages 0, +67.5, +135, and C voltages 0, -4.5, 7.5, -10, and 2 volts for the A supply. If you have any hint on making the power supply I will be most greatful. I was zeners for the 67.5 and 135 volt lines and 790X regulators for the negative lines.
Two of the 30's are a push pull class B amplifier. I called www.tubesandmore.com and they could not find it in ryders. I am betting that it is in there under a different name.
The radio has a filament control on the back of the radio. What is that for? My guess is that it is so you could connect the 6 volt tractor battery to the radio and use the pot to drop the voltage to 2 volts.
It has nine visible paper capacitors that I need to replace.
Thanks Paul
4/3/2001 3:34:38 PMNorm Leal
Hi Guido
Look up Montgomery Wards Model 62-91 in Rider Vol #4, Montgomery Ward 4-4. It should be here on nostalgiaair under Rider schematics. Your actual model may be 62-41 since you were told it's a 41.
I will send you information on building a general power supply. You need to modify it for your radio. I would regulate the "A" section using a LM317 regulator.
The "C" section doesn't need regulation as little (no) current is drawn. Just use a resistor divider with cap to ground at each tap.
The "B" supply doesn't need regulation. Although your radio will draw current 20-30 ma from this supply exact voltage isn't critical. Try to keep voltages within 20%.
: I wish to restore a farm radio that I picked up few weeks ago. It is a Wards Airline Superheterodyne farm radio. I was told that it was a model 41 but I can not find a 41 listed anywhere.
: It has 9 tubes. Three are 34's and six are 30's.
: I will be making a power supply for it and it requires the following B voltages 0, +67.5, +135, and C voltages 0, -4.5, 7.5, -10, and 2 volts for the A supply. If you have any hint on making the power supply I will be most greatful. I was zeners for the 67.5 and 135 volt lines and 790X regulators for the negative lines.
: Two of the 30's are a push pull class B amplifier. I called www.tubesandmore.com and they could not find it in ryders. I am betting that it is in there under a different name.
: The radio has a filament control on the back of the radio. What is that for? My guess is that it is so you could connect the 6 volt tractor battery to the radio and use the pot to drop the voltage to 2 volts.
: It has nine visible paper capacitors that I need to replace.
: Thanks Paul
4/3/2001 11:30:28 PMGuido
: Hi Guido
: Look up Montgomery Wards Model 62-91 in Rider Vol #4, Montgomery Ward 4-4. It should be here on nostalgiaair under Rider schematics. Your actual model may be 62-41 since you were told it's a 41.
: I will send you information on building a general power supply. You need to modify it for your radio. I would regulate the "A" section using a LM317 regulator.
: The "C" section doesn't need regulation as little (no) current is drawn. Just use a resistor divider with cap to ground at each tap.
: The "B" supply doesn't need regulation. Although your radio will draw current 20-30 ma from this supply exact voltage isn't critical. Try to keep voltages within 20%.
: Norm
: : I wish to restore a farm radio that I picked up few weeks ago. It is a Wards Airline Superheterodyne farm radio. I was told that it was a model 41 but I can not find a 41 listed anywhere.
: : It has 9 tubes. Three are 34's and six are 30's.
: : I will be making a power supply for it and it requires the following B voltages 0, +67.5, +135, and C voltages 0, -4.5, 7.5, -10, and 2 volts for the A supply. If you have any hint on making the power supply I will be most greatful. I was zeners for the 67.5 and 135 volt lines and 790X regulators for the negative lines.
: : Two of the 30's are a push pull class B amplifier. I called www.tubesandmore.com and they could not find it in ryders. I am betting that it is in there under a different name.
: : The radio has a filament control on the back of the radio. What is that for? My guess is that it is so you could connect the 6 volt tractor battery to the radio and use the pot to drop the voltage to 2 volts.
: : It has nine visible paper capacitors that I need to replace.
: : Thanks Paul
4/22/2001 12:17:57 AMTEDY
: : Hi Guido
: : Look up Montgomery Wards Model 62-91 in Rider Vol #4, Montgomery Ward 4-4. It should be here on nostalgiaair under Rider schematics. Your actual model may be 62-41 since you were told it's a 41.
: : I will send you information on building a general power supply. You need to modify it for your radio. I would regulate the "A" section using a LM317 regulator.
: : The "C" section doesn't need regulation as little (no) current is drawn. Just use a resistor divider with cap to ground at each tap.
: : The "B" supply doesn't need regulation. Although your radio will draw current 20-30 ma from this supply exact voltage isn't critical. Try to keep voltages within 20%.
: : Norm
: : : I wish to restore a farm radio that I picked up few weeks ago. It is a Wards Airline Superheterodyne farm radio. I was told that it was a model 41 but I can not find a 41 listed anywhere.
: : : It has 9 tubes. Three are 34's and six are 30's.
: : : I will be making a power supply for it and it requires the following B voltages 0, +67.5, +135, and C voltages 0, -4.5, 7.5, -10, and 2 volts for the A supply. If you have any hint on making the power supply I will be most greatful. I was zeners for the 67.5 and 135 volt lines and 790X regulators for the negative lines.
: : : Two of the 30's are a push pull class B amplifier. I called www.tubesandmore.com and they could not find it in ryders. I am betting that it is in there under a different name.
: : : The radio has a filament control on the back of the radio. What is that for? My guess is that it is so you could connect the 6 volt tractor battery to the radio and use the pot to drop the voltage to 2 volts.
: : : It has nine visible paper capacitors that I need to replace.
: : : Thanks Paul
4/3/2001 11:37:32 PMGuido
Norm,
Thanks, It was the 62-41. I printed out the diagram. Now I need to take out my TV-7 A/U tube tester and check the tubes. Build a rubber part that went from the tuning shaft to the dial/condenser gang. Then recap. Build a Power Supply, tune it up and enjoy.
I guess that I will be done in a few weeks.
Take care,
Guido
: Hi Guido
: Norm
: : Thanks Paul
9/6/2003 12:12:42 PMgaspar
Guido,
How did the restoration go? I just picked up a wards airline superhet at a garage sale and just starting to look for info on it. the #'s on the label in the cabinet are Cat# 62-93 and a series # 07B from what i can tell, if anyone has any info that would help id appreciate it.
thank,
gaspar
:Norm,
:Thanks, It was the 62-41. I printed out the diagram. Now I need to take out my TV-7 A/U tube tester and check the tubes. Build a rubber part that went from the tuning shaft to the dial/condenser gang. Then recap. Build a Power Supply, tune it up and enjoy.
:I guess that I will be done in a few weeks.
:Take care,
:Guido
:: Hi Guido
:: Look up Montgomery Wards Model 62-91 in Rider Vol #4, Montgomery Ward 4-4. It should be here on nostalgiaair under Rider schematics. Your actual model may be 62-41 since you were told it's a 41.
:: I will send you information on building a general power supply. You need to modify it for your radio. I would regulate the "A" section using a LM317 regulator.
:: The "C" section doesn't need regulation as little (no) current is drawn. Just use a resistor divider with cap to ground at each tap.
:: The "B" supply doesn't need regulation. Although your radio will draw current 20-30 ma from this supply exact voltage isn't critical. Try to keep voltages within 20%.
:: Norm
:: : I wish to restore a farm radio that I picked up few weeks ago. It is a Wards Airline Superheterodyne farm radio. I was told that it was a model 41 but I can not find a 41 listed anywhere.
:: : It has 9 tubes. Three are 34's and six are 30's.
:: : I will be making a power supply for it and it requires the following B voltages 0, +67.5, +135, and C voltages 0, -4.5, 7.5, -10, and 2 volts for the A supply. If you have any hint on making the power supply I will be most greatful. I was zeners for the 67.5 and 135 volt lines and 790X regulators for the negative lines.
:: : Two of the 30's are a push pull class B amplifier. I called www.tubesandmore.com and they could not find it in ryders. I am betting that it is in there under a different name.
:: : The radio has a filament control on the back of the radio. What is that for? My guess is that it is so you could connect the 6 volt tractor battery to the radio and use the pot to drop the voltage to 2 volts.
:: : It has nine visible paper capacitors that I need to replace.
:: : Thanks Paul
