Information on a Freed Radio
11/20/2000 10:43:29 PMChris Koziol
I have a Freed Radio Model 52. From what my grandmother tells me this, model
is FM and shortly after its purchase the FM radio spectrum was moved out of its tuning spectrum.
I could use some schematics and information to help determine its fate.
As it has a gorgeous walnut cabinet which could be used for another purpose if the radio
can't be salvaged.
11/20/2000 11:19:41 PMNorm Leal
Hi Chris
The schematic for your Freed can be found here on nostalgiaair. After schematics, click on "Rider by Original Index", Freed-Eisemann and 52.
Early FM radios did use a different band. You should be able to receive TV ch #2 on this radio. Keep the radio so it can be passed along in your family.
: I have a Freed Radio Model 52. From what my grandmother tells me this, model
: is FM and shortly after its purchase the FM radio spectrum was moved out of its tuning spectrum.
: I could use some schematics and information to help determine its fate.
: As it has a gorgeous walnut cabinet which could be used for another purpose if the radio
: can't be salvaged.
11/22/2000 9:46:49 PMChris Koziol
Curious. So I can listen to a TV station then. Not much else is in the spectrum then?
Well, I'll see if I can make it work.
: Hi Chris
: The schematic for your Freed can be found here on nostalgiaair. After schematics, click on "Rider by Original Index", Freed-Eisemann and 52.
: Early FM radios did use a different band. You should be able to receive TV ch #2 on this radio. Keep the radio so it can be passed along in your family.
: : I have a Freed Radio Model 52. From what my grandmother tells me this, model
: : is FM and shortly after its purchase the FM radio spectrum was moved out of its tuning spectrum.
: : I could use some schematics and information to help determine its fate.
: : As it has a gorgeous walnut cabinet which could be used for another purpose if the radio
: : can't be salvaged.
1/29/2002 1:14:49 PMGeorge Price
: Hi Chris
I have a Freed-Eisemann Model NR80. Does anyone have a picture of this radio or know where I can find a picture for restoration purposes.
George Price
gprice@pai1.com
