The tube filaments in your Philco require 6.3 volts @ 3 amps. You also need a high voltage center tapped winding 500 to 550 volts @ 70 ma will be ok. Most transformers have a 5 volt winding. Do not connect these wires in your radio. AES part #P-T270DX will work if you have room in the radio.
Since new transformers are expensive you may want to look around for another radio that can be used for parts.
I believe this is one of those Philco's where the original transformer was barely large enough for the job. Before connecting power to a new transformer be sure the electrolytic filter caps have been replaced.
: I just got a Philco 40-150 set that I need a new power
: transformer for. The old one had oozed black tar all
: over the cabinet.After checking continuity, I found
: that the primary winding is open. I have a catalog
: from Antique Electronic Supply and I need to
: order a new one but....which one? The only number I
: have from the old one is a Philco part #: 32-8052N
: If anyone can help, it would be greatly appreciated.
: If more info is needed, let me know....
