Wards Airline Superheterodyne
8/9/2000 10:56:49 AMRIchard
Help, I just bought a Wards Airline Superheterodyne at an antique sale. I am looking for some info in regard to this radio such as when it was built and schematics as it doesn't work.
8/9/2000 11:22:13 AMNorm Leal
Hi Richard
Can you find a model number on the radio? If not listing the tube types may help.
: Help, I just bought a Wards Airline Superheterodyne at an antique sale. I am looking for some info in regard to this radio such as when it was built and schematics as it doesn't work.
8/10/2000 10:39:58 AMRichard
: Hi Richard
: Can you find a model number on the radio? If not listing the tube types may help.
: Norm
: : Help, I just bought a Wards Airline Superheterodyne at an antique sale. I am looking for some info in regard to this radio such as when it was built and schematics as it doesn't work.
8/10/2000 10:44:14 AMRichard
: Norm, I found the following number on the radio - OC 702148. I also wrote down the numbers of the tubes, which most happen to be blown.
3 - tubes # 76
2 - tubes # 46
4 - tubes #6D6
1 - tube #80
1 - tube #SPK
Do you know where I cab buy these tubes?
RIchard
: Hi Richard
: Norm
8/10/2000 11:45:52 AMNorm Leal
Richard
Tubes can be purchased from Antique Electronic Supply, tubesandmore.com and others. Check antiqueradios.com/resources for other suppliers. I would first check flea markets and swap meets as the price of a set can cost a lot of money.
SPK will be a socket where the speaker plugs in.
Are you sure two tubes are 46 and not 45? I found two Wards radios using those tubes except with 45's, Model #62-132 and #62-137. You may be able to find schematics here on nostalgiaair. After schematics, click "Rider by Original Index".
: : Norm, I found the following number on the radio - OC 702148. I also wrote down the numbers of the tubes, which most happen to be blown.
: 3 - tubes # 76
: 2 - tubes # 46
: 4 - tubes #6D6
: 1 - tube #80
: 1 - tube #SPK
: Do you know where I cab buy these tubes?
: Thanks
: RIchard
: : Hi Richard
: : Can you find a model number on the radio? If not listing the tube types may help.
: : Norm
: : : Help, I just bought a Wards Airline Superheterodyne at an antique sale. I am looking for some info in regard to this radio such as when it was built and schematics as it doesn't work.
11/5/2000 12:42:48 AMBruce Eddy
Richard
The Airline radio you have was manufactured for Montgomery Ward by Wells-Gardner & Co. of Chicago. The 0C that procedes the serial number is the W-G chassis number. The schematic is in Riders Vol. 5, Wells-Gardner pages 1-2. Wards used this in several models, including the ones Norm noted. Rider Vol. 5, Montgomery Ward pages 8-10.
Bruce
: Richard
: Tubes can be purchased from Antique Electronic Supply, tubesandmore.com and others. Check antiqueradios.com/resources for other suppliers. I would first check flea markets and swap meets as the price of a set can cost a lot of money.
: SPK will be a socket where the speaker plugs in.
: Are you sure two tubes are 46 and not 45? I found two Wards radios using those tubes except with 45's, Model #62-132 and #62-137. You may be able to find schematics here on nostalgiaair. After schematics, click "Rider by Original Index".
: Norm
: : : Norm, I found the following number on the radio - OC 702148. I also wrote down the numbers of the tubes, which most happen to be blown.
: : 3 - tubes # 76
: : 2 - tubes # 46
: : 4 - tubes #6D6
: : 1 - tube #80
: : 1 - tube #SPK
: : Do you know where I cab buy these tubes?
: : Thanks
: : RIchard
: : : Hi Richard
: : : Can you find a model number on the radio? If not listing the tube types may help.
: : : Norm
: : : : Help, I just bought a Wards Airline Superheterodyne at an antique sale. I am looking for some info in regard to this radio such as when it was built and schematics as it doesn't work.
1/11/2002 11:21:58 PMLarry Bolfing
The radio ser # is 04wg1108a, Can you give me some info on this?
: Bruce
: : Richard
: : Tubes can be purchased from Antique Electronic Supply, tubesandmore.com and others. Check antiqueradios.com/resources for other suppliers. I would first check flea markets and swap meets as the price of a set can cost a lot of money.
: : SPK will be a socket where the speaker plugs in.
: : Are you sure two tubes are 46 and not 45? I found two Wards radios using those tubes except with 45's, Model #62-132 and #62-137. You may be able to find schematics here on nostalgiaair. After schematics, click "Rider by Original Index".
: : Norm
: : : : Norm, I found the following number on the radio - OC 702148. I also wrote down the numbers of the tubes, which most happen to be blown.
: : : 3 - tubes # 76
: : : 2 - tubes # 46
: : : 4 - tubes #6D6
: : : 1 - tube #80
: : : 1 - tube #SPK
: : : Do you know where I cab buy these tubes?
: : : Thanks
: : : RIchard
: : : : Hi Richard
: : : : Can you find a model number on the radio? If not listing the tube types may help.
: : : : Norm
: : : : : Help, I just bought a Wards Airline Superheterodyne at an antique sale. I am looking for some info in regard to this radio such as when it was built and schematics as it doesn't work.
5/17/2002 4:54:50 PMRichard Arnold
: Richard
: The Airline radio you have was manufactured for Montgomery Ward by Wells-Gardner & Co. of Chicago. The 0C that procedes the serial number is the W-G chassis number. The schematic is in Riders Vol. 5, Wells-Gardner pages 1-2. Wards used this in several models, including the ones Norm noted. Rider Vol. 5, Montgomery Ward pages 8-10.
: Bruce
: : Richard
: : Norm
: : : 1 - tube #80
: : : 1 - tube #SPK
: : : Thanks
: : : RIchard
: : : : Hi Richard
: : : : Norm
12/2/2001 7:20:18 PMDOUGLAS EHRENHAFT
HI I ALSO HAVE A BEAUTIFUL A 1929 AIRLINE MODEL
AE11 IT HAS A BEAUTIFUL CABINET BUT DOESNT WORK I LIVE IN EVANSVILLE IND. AND CANT FIND ANYONE THAT ISNT DEAD TO WORK ON IT. ANY HELP WOULD BE APPRECIATED
