Antique Electronic Supply, tubesandmore.com , does carry some IF Transformers.
You may want to repair the ones in the Silvertone. If the coils are open look for broken wires where they connect to the transformer leads. When checking these transformers be sure there aren't other components in the can which make them seem bad.
: : I have a Silvertone 4 band SW receiver in need of two parts. I need the 1st and 2nd IF transformers, Silvertone part # 10-128-2 and 10-129-2. Who might have these parts or a cross over that might work? thanks,Robert
: Antique Electronic Supply, tubesandmore.com , does carry some IF Transformers.
: You may want to repair the ones in the Silvertone. If the coils are open look for broken wires where they connect to the transformer leads. When checking these transformers be sure there aren't other components in the can which make them seem bad.
: Norm
: : : I have a Silvertone 4 band SW receiver in need of two parts. I need the 1st and 2nd IF transformers, Silvertone part # 10-128-2 and 10-129-2. Who might have these parts or a cross over that might work? thanks,Robert
Norm, Thanks for the reply. Antique Radio Supply is right down the street from me and no luck there. These parts are missing so the test thing went out the window. I managed to come up with a photofact so far. I think the parts cross over might be the way to go if I can get a cross over number. Thanks again,Robert
