Don't rebuild the caps in a Radiola III unless you know they are bad. All are small values and are usually ok. Rider has values written in. The cap with green band is .00025 with a 2 meg built in for grid leak. Across the audio interstage transformer is .001 mfd. The others below the coil as shown as 10, 50, 250 pf. One isn't written in..
No phillips screws should be used in these radios!
: Have a Radiola III to restore, does any know the
: capacitance and voltage rating of the 6 cap., and the
: grig resistor ?
: I thought I saw here, but cant find anymore, a source a
: price for someone who rebuilds these caps with new ones inside.
: and laslly are the 4 screws around the tube hole suspose to be
: phillips head screws?
: Thanks
: Jack
