Those eye tubes lose some of their green after a few hundred hours of operation. The tube may be good on a tester meter and still not have much green. Check your tube type, replacements are available from Antique Electronic Supply, tubesandmore.com and others.
If your radio has a power transformer you will have some improvement lighting the dial using #44 lamps. The #47 has a 6.3 volt @ .15 amp filament while the #44 has a .25 amp filament and will be brighter.
: have an Radio Products Company model 7g
: the eye tube works but to see it the room lights
: have to be turned down low.Any ideas ? (all the tubes were replaced)
: also what type dial light lamps are suspose to be used?
: my schematic dosen't say the prev.owner had type 47 bay
: net 6.3v type, but they only light up the sides of the
: 7 or 8 inch dial.
: any help will be greatily apreciated
: thanks
