You can find information on replacing a electrodynamic speaker with a pm type at:
http://www.flash.net/~billhar/tips.htm
look under "Electrodynamic Speakers"
: You can find information on replacing a electrodynamic speaker with a pm type at:
: http://www.flash.net/~billhar/tips.htm
: look under "Electrodynamic Speakers"
Hi Dave
The Philco 20 uses push-pull 71 tubes. Your Hammond 125, I believe, is a universal push-pull 3 watt transformer. A plate to plate load resistance of 5k will work fine. I would use any inexpensive choke 5-10 henries which can carry at least 50ma to replace the speaker field. The total current drawn by the 71's, 24's and 27 will be near 50ma. Good luck, Norm
: : You can find information on replacing a electrodynamic speaker with a pm type at:
: : http://www.flash.net/~billhar/tips.htm
: : look under "Electrodynamic Speakers"
: Hi Dave
: The Philco 20 uses push-pull 71 tubes. Your Hammond 125, I believe, is a universal push-pull 3 watt transformer. A plate to plate load resistance of 5k will work fine. I would use any inexpensive choke 5-10 henries which can carry at least 50ma to replace the speaker field. The total current drawn by the 71's, 24's and 27 will be near 50ma. Good luck, Norm
Hi , All of you
I have a Philco 20 that I picked up at a yard sale for $25.00 CDN . I found this site last fall ,found the diagram,and thought I would print it out when I had time to work on it.
Lo and behold , that wonderful service is no longer availabe . I was really thrilled when I saw it ,but now - - - - ?How can I get the diagram back ?
Dan
: Hi Dave
Hi , All of you
Dan
