Need Help RCA T4-8A
5/21/1999 11:58:00 AMBob Carpenter
Need schematic for RCA T4-8A (in Rider Vol 7-5).
Its not the same as a T4-8 (Rider Vol 6), the second
detector is layed out different. I have Vol 6 but not
Vol 7. This set has a problem of very low audio. If
signal is injected into G1 of #41 output tube, sounds
fine. Signal trace up to detector is ok.
Something wrong in detector circuit. Also, weired
volume control setup in this one. If you have schematic
post here or send reply of e-mail addrees and can transfer
by e-mail.
PS for NORM LEAL, I have a copy of Rider Index manul, good
thru Vol 16. Would it benifit you to scan it and have it
placed here on the Internet.
Bob
5/21/1999 12:17:17 PMNorm Leal
Hi Bob
I'll email you the schematic from Rider Vol 7-5. It also has a wiring layout of the radio.
Thanks for the offer to scan the index but please contact Richard Landcaster at richard@nostalgiaair.org. He has the index but I am sure he would appreciate your help.
: Need schematic for RCA T4-8A (in Rider Vol 7-5).
: Its not the same as a T4-8 (Rider Vol 6), the second
: detector is layed out different. I have Vol 6 but not
: Vol 7. This set has a problem of very low audio. If
: signal is injected into G1 of #41 output tube, sounds
: fine. Signal trace up to detector is ok.
: Something wrong in detector circuit. Also, weired
: volume control setup in this one. If you have schematic
: post here or send reply of e-mail addrees and can transfer
: by e-mail.
: PS for NORM LEAL, I have a copy of Rider Index manul, good
: thru Vol 16. Would it benifit you to scan it and have it
: placed here on the Internet.
: Bob
5/25/1999 11:47:01 AMBob Carpenter
: Hi Bob
: I'll email you the schematic from Rider Vol 7-5. It also has a wiring layout of the radio.
: Thanks for the offer to scan the index but please contact Richard Landcaster at richard@nostalgiaair.org. He has the index but I am sure he would appreciate your help.
: Norm
: : Need schematic for RCA T4-8A (in Rider Vol 7-5).
: : Its not the same as a T4-8 (Rider Vol 6), the second
: : detector is layed out different. I have Vol 6 but not
: : Vol 7. This set has a problem of very low audio. If
: : signal is injected into G1 of #41 output tube, sounds
: : fine. Signal trace up to detector is ok.
: : Something wrong in detector circuit. Also, weired
: : volume control setup in this one. If you have schematic
: : post here or send reply of e-mail addrees and can transfer
: : by e-mail.
: : PS for NORM LEAL, I have a copy of Rider Index manul, good
: : thru Vol 16. Would it benifit you to scan it and have it
: : placed here on the Internet.
: : Bob
Norm, Thanx for the schematic. One question, did the
second detector change to a 6B7 for the T4-8A. The number
is not real clear on the schematic. The older T4-8 used
a 6F7, which would explain why the T4-8A radio on my bench
looked so different compared to the T4-8 schematic in
Rider's Vol 6.
Bob
4/17/2000 7:06:07 PMEagle's Nest at Marco
: Hi Bob
: Norm
: : by e-mail.
: : Bob
