Dial Lamp for Philips H88U - 08
5/17/1999 4:33:29 PMFrank Buchacher
Hello,
I need the characterisics of a Dial Lamp Type 8095D.
It was in a Philips Radio Set Type H88U - 08.
The Radio was for the european market and was build in
the middle 40´s.
5/19/1999 4:18:29 PMGidi Verheijen
Dial lamp 8095 D was used in several Philips radios in the period 1942 to 1948 (and maybe earlier and later). It is a 6,3 volt and 0.32 A type with miniature screw and a "long" glass. The dimensions are the same as the American lamp types no 40, 41, 42, 46 and 48: length 1 1/8", diameter 13/32".
: Hello,
: I need the characterisics of a Dial Lamp Type 8095D.
: It was in a Philips Radio Set Type H88U - 08.
: The Radio was for the european market and was build in
: the middle 40´s.
5/19/1999 7:50:42 PMNorm Leal
Hi
Since Gidi knows it is the screw base style lamp, I suggest using the number 46 which is rated 6 volts at .25 amps. The 40 is 6 volts at .15 amps and the others are rated at 2 to 3.2 volts.
: Dial lamp 8095 D was used in several Philips radios in the period 1942 to 1948 (and maybe earlier and later). It is a 6,3 volt and 0.32 A type with miniature screw and a "long" glass. The dimensions are the same as the American lamp types no 40, 41, 42, 46 and 48: length 1 1/8", diameter 13/32".
: : Hello,
: : I need the characterisics of a Dial Lamp Type 8095D.
: : It was in a Philips Radio Set Type H88U - 08.
: : The Radio was for the european market and was build in
: : the middle 40´s.
