Vert Osc/Output are the right circuits. Measure voltages on both sections of the tube.
Connecting a .1 mfd cap between grid of output stage and filament should show some deflection if that section is ok. This is for test only as picture will not lock in.
: The technical forum form won't come up so I'll post this here. Have lost vertical deflection in my RCA CTC-11 chassis. Single line across the screen. Replacment of the 6EM7(6EA7) Vert out/osc. tube did not help. Service-normal switch good; is there anything that would normally cause this that I'm missing? thanks
: Vert Osc/Output are the right circuits. Measure voltages on both sections of the tube.
: Connecting a .1 mfd cap between grid of output stage and filament should show some deflection if that section is ok. This is for test only as picture will not lock in.
: Norm
: : The technical forum form won't come up so I'll post this here. Have lost vertical deflection in my RCA CTC-11 chassis. Single line across the screen. Replacment of the 6EM7(6EA7) Vert out/osc. tube did not help. Service-normal switch good; is there anything that would normally cause this that I'm missing? thanks
After looking further I found a burned cap, C507. THANKS
