I need technical informations for this amplifier :
High Fidelity Laboratories Power Amplifier
PHILIPS Type 22AH578/00
(1976 I think, made in USA)
There are 16 transistors TO-3... One of them is failing... On the transistor is written :
Toshiba 355-1
0 .827
Nobody knows this type of transistor... So help me if u can... What sort of transistor is that ?!? Somebody know where I can found it ?!?...
thx bye !
: I need technical informations for this amplifier :
: High Fidelity Laboratories Power Amplifier
: PHILIPS Type 22AH578/00
: (1976 I think, made in USA)
: There are 16 transistors TO-3... One of them is failing... On the transistor is written :
: Toshiba 355-1
: 0 .827
: Nobody knows this type of transistor... So help me if u can... What sort of transistor is that ?!? Somebody know where I can found it ?!?...
: thx bye !
: : I have technical informations for this amplifier :
: : High Fidelity Laboratories Power Amplifier
: : PHILIPS Type 22AH578/00
: : (1976 I think, made in USA)
: : There are 16 transistors TO-3... One of them is failing... On the transistor is written :
: : Toshiba 355-1
: : 0 .827
If you have the information about the 22ah578
may i have acopy of it
Say what you want for it!
Give me an Email
chicono1@home.nl
: : : I have technical informations for this amplifier :
: : : High Fidelity Laboratories Power Amplifier
: : : PHILIPS Type 22AH578/00
: : : (1976 I think, made in USA)
: : : There are 16 transistors TO-3... One of them is failing... On the transistor is written :
: : : Toshiba 355-1
: : : 0 .827
Hi
I own one of these amplifiers. I have replaced the output transistors a few times with the Motorola MJ15024. They work just fine. I was wondering if you had access to the schematic for this amp. I am also looking for replacement parts and I cant find cross reference for one of the transistors on the driver board. The trans is mounted on a small heat sink and stamped 6102 63-6. Hope you can help me.Thanks
Don
: Toshiba 355-1
: 0 .827
: thx bye !
Hello,
I use these typ of transitor :
MJ 15024
R C A
H A 8327
These are Motorola types.
I us all 16 of them
So i hope that i can help so far.
Good luck greeting Fred
