old Harman Kardon stereo amp
10/6/1999 8:08:34 PMLeo Van Vliet
does anyone know anything about old tubetype Harman Kardon amps? The amp is model A300. How many watts per channel etc. Any info is appreciated. Thanks
10/9/1999 7:19:08 AMErich Loepke
: does anyone know anything about old tubetype Harman Kardon amps? The amp is model A300. How many watts per channel etc. Any info is appreciated. Thanks
What tubes does your amplifier use? Usually you can guess at power output if you know which tubes are used in the output stage. I have a model A500 which is about 35 watts per channel. I assume the A300 is a similar type amplifier with possibly less power output.
12/2/1999 12:48:40 PMScott
I have an old H/K a-1040...anyone know the wattage?? Or perhaps where I can find a manual for it?
: : does anyone know anything about old tubetype Harman Kardon amps? The amp is model A300. How many watts per channel etc. Any info is appreciated. Thanks
: What tubes does your amplifier use? Usually you can guess at power output if you know which tubes are used in the output stage. I have a model A500 which is about 35 watts per channel. I assume the A300 is a similar type amplifier with possibly less power output.
11/11/2000 11:50:12 AMBlain Konkle
The A 300 produces about 12 - 14 watts per channel, depending on who's output tube your using. For an amplifier of so little power, it sounds phenominal !! I have a copy of the schematic, somewhere. It lists voltages to measure and some resistance readings, but that's about it. Contact me and I can mail you a copy.
6/5/2001 12:57:19 PMFrank
Dear Blain,
Could U pls. to send me any information about A 300?
THX
: The A 300 produces about 12 - 14 watts per channel, depending on who's output tube your using. For an amplifier of so little power, it sounds phenominal !! I have a copy of the schematic, somewhere. It lists voltages to measure and some resistance readings, but that's about it. Contact me and I can mail you a copy.
6/9/2000 9:07:14 PMbarry marks
12/2/2000 9:38:31 AMeddie lien
hi
does anyone know how old the H/K Tube Amp a-500 manufactured?1980?or 1970?
pls mail to me
12/2/2001 10:36:32 PMnick
your model allows 42.2 watts a channel with no more than 0.8 thd (total harmanic distortion)
6/9/2000 9:16:22 PMbarry marks
well i have had my A300 for over 10 yrs. it uses 6V6"s in push pull so it has around 12 watts per channel. i use advent model #1 speakers and the sound is fantasic. dont let the low power fool you. these are tubes not transisters. a subwoofer is not needed. i hope you enjoy it as much as i do.
b.marks
