5/5/1999 9:23:19 AMPeter Lehmann, DG7BAM(12180:0)
I need informations on my Rodec Auditorium amplifier.
It is a 2* 15W type with 4* EL 84 and 7* ECC83.
It has preamps for both mm cartridges and microphones
and of course inputs for tuner, tape and crystal cartridges.
Capacitors and resistors are Philips made, the transformers
looks like Philips made so i think it`s made in the
nederlands.
Thanks for help
Peter
1/5/2000 10:49:41 AMJean-Paul Benmokaddem(12378:12180)
Following the request of Mr by Peter Lehmann, DG7BAM concerning his Rodec, I alos have a Rodec Integrated Tube amplifier with the same Tubes (ECC83) but instead of the EL84, my amplifier uses EL95 which are a bit smaller thant the EL84. Now I am wondering if Mr Peter Lehmann is quite sure about the reference for the EL84.
My request is to find the schema of this amplifier.
Thanks for help
Jean-Paul
1/23/2001 2:54:55 AMawi(12907:12378)
: Following the request of Mr by Peter Lehmann, DG7BAM concerning his Rodec, I alos have a Rodec Integrated Tube amplifier with the same Tubes (ECC83) but instead of the EL84, my amplifier uses EL95 which are a bit smaller thant the EL84. Now I am wondering if Mr Peter Lehmann is quite sure about the reference for the EL84.
: My request is to find the schema of this amplifier.
: Thanks for help
: Jean-Paul
1/23/2001 2:55:36 AMawi(12908:12378)
: Thanks for help
: Jean-Paul
