If you do not have any luck finding the number: If you have a tube tester with the ability to test the "01A" series tubes, you may need to use 4 leads with banana jacks on one end, and clips on the other. Set filament voltage to zero first, as you will turn up the voltage incrementaly to 1.5, 2.5, 3 then 5. If at any point the tester indidcates a strong tube reading; that is your filament voltage. Realisticaly that voltage will be at 5 volts, which is the 201A,101A and 301A. DeForrest made 401A's that are supposed to be 3 volt filaments.
The blue tubes are probably Arctrus, but one or two other small companies had colored glass too.
: : Gentlemen: I picked up a couple of radios recently and can not seem to find any info on them. Would like to know if they are fairly common or somewhat rare. The 1st being a Columbia Model C11 console. The 2nd has no model #. It is a old battery radio I would guess it to be 1915 to early 20s. It has worn painted front saying Melodee on it. It uses 5 tubes all being the same but no #s or markings. They are a 4 pin (short 1/4") globe
: : tube all being blue in color. Any help identifing these radios and the tubes used in the old battery one.
: : Many Thanks in advance...Ralph
Try resodering pins on your tube with open filament. Even if bad a blue 201A would be worth $5.00.
: Glen,Don,John & Alan: Thank you all for your information. Don you asked where I lived, in central IL. After reading your posts, I dug thru my old stuff and found a Supreme Instruments model 400 tube tester which had 01A listed. Gentlemen you were right, as 4 out of 5 tested good,(1 open fil.)Thanks again to all for the info on the tubes and old radios.
: Ralph
what is a good blue 201A worth? Thanks again....Ralph
Don't see an Arturus 201A listed in Geroge Fathauer price list. Would think a good blue one would sell around $25.00. Do a search on eBay and see what has been sold. Even bad blue tubes would have a value, $10? You can contact George at tubes@uswest.net .
: Norm: Thank you, I did try to resolder but will try one more time for good measure. Just out of curiosity,
: what is a good blue 201A worth? Thanks again....Ralph
