Philco 51-930 Schematic and Resistor.
4/15/1999 10:45:36 PMDavid H
Philco 51-930 has a 5K ohm resistor in it. It looks like it may be a 5 Watt power resistor but will not operate when replaced. Resistor measures 5K Ohms and is a carbon type but the ends are loose and will not last much longer. What is it. Feeds the 7A8 tube.
System also has many other resistors in bad shape. A schematic with values would be very helpful.
4/15/1999 11:07:23 PMNorm Leal
: Philco 51-930 has a 5K ohm resistor in it. It looks like it may be a 5 Watt power resistor but will not operate when replaced. Resistor measures 5K Ohms and is a carbon type but the ends are loose and will not last much longer. What is it. Feeds the 7A8 tube.
: System also has many other resistors in bad shape. A schematic with values would be very helpful.
Hi David
The schematic of the Philco 51-930 is in Rider #21 and Sams Photofact #153. These may be available from your local library. I will send you a schematic from Rider but the values are hard to read. Do not see any resistor marked 5K. If you have a power resistor with voltage on one side and nothing on the other, there may be a capacitor shorted to ground on the side without voltage.
4/15/1999 11:09:26 PMNorm Leal
: : Philco 51-930 has a 5K ohm resistor in it. It looks like it may be a 5 Watt power resistor but will not operate when replaced. Resistor measures 5K Ohms and is a carbon type but the ends are loose and will not last much longer. What is it. Feeds the 7A8 tube.
: : System also has many other resistors in bad shape. A schematic with values would be very helpful.
: Hi David
: The schematic of the Philco 51-930 is in Rider #21 and Sams Photofact #153. These may be available from your local library. I will send you a schematic from Rider but the values are hard to read. Do not see any resistor marked 5K. If you have a power resistor with voltage on one side and nothing on the other, there may be a capacitor shorted to ground on the side without voltage.
: Norm
: David
Please send your email id if you still need the schematic..
6/15/1999 12:02:36 PMWalton Bronstetter
: Hi David
: Norm
: I have the Home Radio Yearbook 1951 From Philco coporation for 51-930 Schematic and parts list.
You can e-mail me for details.
:walton
4/16/1999 11:32:11 PMDavid H
6/15/1999 11:48:16 AMWalton Bronstetter
12/30/2000 1:35:47 PMWalton L. Bronstetter
